TRANSMISSION
Old Mar 4, 2008 | 07:33 PM
phat cat's Avatar
Default TRANSMISSION
i was riding my atv the other day and its a 07 400 manual i was in 4th gear and the atv jerked and went in to 5th gear with out me changing gears i tried to see if it does it in any other gear but it dont only 4th gear does anyone know what would couse this?
Old Mar 4, 2008 | 11:59 PM
phat cat's Avatar
ANYONE?
Old Mar 5, 2008 | 04:51 PM
swampyjunior's Avatar
Phat cat,
Since you machine is a manual shift I am going to assume it has the rocker shifter? If this is the case you you accidently bump the lever it can jump into a higher or lower gear. I used to do this until I became used to keeping my big feet out of the way. I mostly did this when going up steep hills and leaning over the handlebars.
Either that or your clutch may need some adjusting. That is all I can think of to help you out.
SJ
Old Mar 13, 2008 | 12:55 PM
phat cat's Avatar
thanxx bro i have had it for a year or so id say im use to driving it so i would go with the clutch
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
