Mixing oils bad or good
Almost all Synthetic state on the bottle that they can be mixed with regular oil. Mixing oil info
I even read sites that say if your going to use blends to try and say money you might as well blend it yourself for a higher ratio since off the shelf blends only contain 10-20% synthetic at most and are a rip off.
there is only like a cup of oil at most in the crank case if not removed so it would be pretty diluted.
I don't remove the crank case drain plug ,I just start the ATV up for a second with the oil tank drain lug still out and it will squirt out that little bit of oil out also.
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
