Mixing oils bad or good
Old Mar 5, 2008 | 09:10 PM
nickatnite's Avatar
Default Mixing oils bad or good
i just changed the oil in my sp 500. i put mobil 1 0w 40 in and i forgot to drain the crankcase of the polaris oil. is this a big problem or no???
Old Mar 5, 2008 | 10:04 PM
sprinter10's Avatar
i wouldn't think it is.
Old Mar 5, 2008 | 10:17 PM
03scrambler500's Avatar
nope.
Old Mar 6, 2008 | 07:42 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
as long as you had synthenic oil in there it wouldnt be a big deal.
Old Mar 6, 2008 | 12:23 PM
TLC's Avatar
TLC
Almost all Synthetic state on the bottle that they can be mixed with regular oil. Mixing oil info
I even read sites that say if your going to use blends to try and say money you might as well blend it yourself for a higher ratio since off the shelf blends only contain 10-20% synthetic at most and are a rip off.
there is only like a cup of oil at most in the crank case if not removed so it would be pretty diluted.
I don't remove the crank case drain plug ,I just start the ATV up for a second with the oil tank drain lug still out and it will squirt out that little bit of oil out also.
tmoose
Jun 30, 2015 08:28 AM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
Fnqrider
May 31, 2015 08:29 AM
neilbedwell
May 29, 2015 02:24 PM
