Kodiak Drive Problem...only drives in neutral
Old Mar 8, 2008 | 09:58 PM
priesman64's Avatar
Default Kodiak Drive Problem...only drives in neutral
Ok guys
just got my kodiak out in the snow and after riding it then putting it away i went to ride again and i could only drive in neutral.....it had no reverse or hi but when i would start it in neutral it would be in gear....any thoughts?
thanks in advance
Nick
Old Mar 8, 2008 | 11:58 PM
hondabuster's Avatar
Linkage out of adjustment? Was the green neutral light on?
Old Mar 9, 2008 | 12:26 AM
pagerboy's Avatar
Adjust the linkage probably, mine got totally loose so I put thread locker on.
Old Mar 9, 2008 | 10:59 AM
priesman64's Avatar
yeah the light was on that and when i would have it in hi or reverse all it would do is grunt like it was trying to go but it just wouldnt it also sounded like my belt was slipping too but im not sure
Old Mar 9, 2008 | 12:30 PM
pagerboy's Avatar
I have also found out that if the light isn't on neutral then it isn't in neutral, it will still be on the last position it was.
I was in high then tried to get it in neutral and I know the shifter was there but the light wasn't on so it still thinks its in high.
Old Mar 9, 2008 | 09:42 PM
priesman64's Avatar
so you think that my linkage it out of wack but what about my reverse?
Old Mar 14, 2008 | 04:17 PM
priesman64's Avatar
or will fixing my linkage fix my reverse too?
Old Apr 21, 2008 | 10:25 PM
priesman64's Avatar
are you talking about the rod going from my shifter to my engine case area? or the dashboard area ................ also when i have it in any gear it's always locked up i can push it backwards in neutral (so it says im in neutral) but its hard as hell to move that and now when i get it started when i try and give it gas it stalls me out every time but it will idle fine
any pointers....im to my last nerve about time to take it to the dealership at last resort
thanks
Old Jun 7, 2009 | 09:55 PM
grizz450se's Avatar
Im having the same problem what corrects it?
Old Jun 14, 2010 | 06:34 AM
CraZySteve's Avatar
I am too! What is the FIX ????
scram5050
Aug 30, 2024 01:39 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
toonces
Jul 31, 2015 09:27 AM
tporath
Jul 11, 2015 12:31 PM
