ITP Wheels
Old Mar 9, 2008 | 08:46 PM
awsume800efi's Avatar
Default ITP Wheels
Hey guys I am going to buy some ITP C-series type 5 or 6 wheels for my 800 efi, i have mudlite 26x10 on the front, what offset is required so i no longer have to use the spacers? it seems like the rim comes with a 4+3 is that correct or is there a different offset i need? Thanks alot guys you always seem to save people time and money, keep on wheelin!
Old Mar 11, 2008 | 10:13 AM
Default ITP Wheels
thanks for the help guys
Old Mar 11, 2008 | 10:55 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default ITP Wheels
i have type 7 wheels w/ a 9" tire an di beleave you could put 10" on w/the same offset. just ask the delaer your buying them from what the differnces are.
Old Mar 11, 2008 | 11:13 AM
Sport400inOH's Avatar
Default ITP Wheels
The offset first number is from the center of the mounting part (Where the bolt holes are) to the inside bead edge. The 2nd number is from the center of the mounting part to the outside bead edge. Both numbers must add up to the rim width between the beads (Your example from above - 4+3 =7" width).
If your stock rim offset is 4+3 (7" wide rim), then go with 3+4 and gain 2" of total width (total including both sides). If you want even more, go with 2+5 for 4" of total additional width compared to the 4+3 rims.
Old Mar 11, 2008 | 08:20 PM
Default ITP Wheels
thank you very much guys i sure appreciate the help
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
