loose lug bolts on 350 rancher??
me friend just out rims on from a different quad with tires just to see if they fit. got them free. he came to me and showed be that one lug nut wasnt tighting. and the bolt was moving around. and then it happened again with another and you cant tighten them cause is just spins. i noticed that there is a like a groove on stock nuts is that so it sits in the stock rim and make it tighten?? help with this would be SWEET. I AM A POALRIS GUY BUT IM HELPING THIS GUY OUT. so im kind of out of my field here
thanks
thanks
Stud is stripped out, try taking it off while using a flat top screw driver behind it to keep pressure on the nut while spinning it backwards. Or, take off all the other lug nuts then have one buddy pulling out on the wheel while the other turns the problem nut backwards to take it off. If this dont work youll have to cut it off, no big deal since the stuc has to be replaced anyway.
