Hi-Bird Atv Power
Old Mar 12, 2008 | 01:24 AM
atvjunkman's Avatar
Default Hi-Bird Atv Power
Hello all,
I'm a newbie here posting,but have read just about every topic here.Anyway I'm having a problem with a Hi-Bird 250stw atv that I bought a month ago.Its running like a car thats low on transmission fluid.Its winding out with no power.Could it be the clutch.If anyone can help,it would very much be appreciated.
Old Mar 12, 2008 | 10:52 AM
SilveradoSS's Avatar
What kind of motor oil do you have in it? It could be a clutch problem. Does it rev up without a corresponding increase in speed?
Old Mar 16, 2008 | 06:19 PM
atvjunkman's Avatar
I'm using rotella 15w 40, but thats not it because thats the reason I changed the oil.When I press on the throttle the rpms go up but no power.My driveway has a small incline and I'll back it down the driveway about 60ft and it has no power to go back up.If I stay on the throttle it will eventually make it back up the driveway.I don't think its the carb.I would think if its the clutch I wouldn't be able to crank it in gear by pressing the clutch and key.I have no clue but I'll be finding out if I have to tear the whole thing apart.
Old Mar 16, 2008 | 08:24 PM
Whiskers's Avatar
I think you have the wrong oil in your unit. These things all use the same oil as in Yamahas or whatever. But it is not just regular motor oil. It is a special oil for quads that has the right formula for the clutch. I use taht Rotella in my Deisel truck ! Just go to any bike shop and ask them for what you need. It uses the same oil in the crankcase and primary drive.
Old Mar 16, 2008 | 10:05 PM
kczukiman's Avatar
Hey Whiskers you old dog how ya doing?Good to see ya back sharing info [img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 19, 2008 | 01:03 AM
atvjunkman's Avatar
Thanks Whiskers for the reply.Someone on another topic said that rotella is the same as the other oils in the other atvs.My atv started doing this before I changed the oil.But I'll try the other oil,just to see.
Old Mar 19, 2008 | 12:52 PM
outofline's Avatar
Have you adjusted the Clutch (cable)? If it's not adjusted correctly it will do this very thing!
Old Mar 20, 2008 | 12:25 AM
atvjunkman's Avatar
Outofline I talk to a man at an atv shop and he said the same.I tightened the cable because I thought there was too much slack but that what it is.Thanks for all of your help.
Old Mar 20, 2008 | 12:38 AM
outofline's Avatar
So it sounds like it worked? Glad to be of a help!
Old Mar 30, 2008 | 11:46 AM
Whiskers's Avatar
Hey, KCzukiman ! I just spotted your avitar in another thread and thought the same thing. I've been reading threads but the old Tornado thread got quiet. I tell ya, my wifes hi bird still goes great and my panther is even better. I'm slower but still ridin! You keep well!
