Blaster Problems!!! Need Help!!
Old Mar 13, 2008 | 11:16 AM
levste65's Avatar
Default Blaster Problems!!! Need Help!!
04 Stock Blaster, idles really high with clutch pulled in. once the clutch is out, it runs fine. does the same thing in neutral. idle screw is not doing anything. this problem just started, the quad ran fine before. im thinking air somewhere??
Old Mar 13, 2008 | 02:41 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
You mean when you let out the clutch it idles down then pull the clutch again and it's still ok? If so I have one doing the same thing. Pretty sure it's a air leak.
Old Mar 13, 2008 | 07:51 PM
qsportgoat's Avatar
could be air somewhere ,but mine did this once, it was the tors. malfunctioning,once it was eliminated it was ok. hope this helped
Old Mar 13, 2008 | 11:21 PM
Terrellster's Avatar
I have two of them and I found that the cable on the older one was not adjusted and tightened in place as it should have been. Check the cable at the throttle assembly and make sure it's good.
Both of mine have the TORS still working on them. Although gsportgoat has a good point I hardly think the actual electronics would be a problem, but I can imagine a bad switch at one location or another. I bypassed the switch in the throttle lever assembly on the 89 to troubleshoot and it caused that high RPM symptom. I fixed it proper and have no issue at all now. Eventually I will be bypassing the TORS so I can run a different type of Kill Switch. I like the Tether type switches and think they would be preferable to the electronic TORS system. I also think the Racing circuits all REQUIRE a tether type kill switch to compete.
I might be wrong about the "all" part, but If <u>they</u> require it for safety, I can't imagine anything better.
Old Mar 22, 2008 | 02:32 AM
Sandnutz5's Avatar
Blasters had problems with the cylinder base gasket blowing out by the transfer ports and causing an air leak- usually it is visible by just looking at it- it will cause symptoms from a very high idle to runaway engine speed in nuetral- Its easy to fix by just replacing the base gasket .
Frisky2050
Apr 9, 2020 11:19 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
joeyupton
Jul 14, 2015 11:51 AM
