250sx Electrical
Old Mar 13, 2008 | 03:04 PM
stevehenderson's Avatar
Default 250sx Electrical
My bike after sitting winter starts on kicker, but the lights and
starter and neutral light no longer work. I was looking @ the wiring
diagram and I cant see how this is possible.
Dose CDI unit get power from the wire that goes to the Alternator if
not which wire / pin? There are six wires to CDI.
Old Mar 15, 2009 | 09:02 PM
chevyhondacatdeere's Avatar
Is your battery dying? If the neutral light isn't working and the battery isn't dead and it is in neutral then it might be the wire under the motor going to the neutral switch. They come loose very easy.
Old Mar 18, 2009 | 10:42 PM
nitrokev's Avatar
yeah I had the same problem then i found that stupid connection on the right side.
also if that doesnt work there was a conection on the left side that was corroded and it was stopping the starter from working.
Old Mar 20, 2009 | 12:14 PM
odysseyjunk's Avatar
the cdi probably works on its own stator coil, separate from the lighting coil.... so it will run even if no lights or anything work. depending on how its wired, a really stone dead battery could stop everything from working, and after sitting all winter and possibly freezing, thats a good place to check....
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
