ETC Adjustment?
Old Mar 13, 2008 | 05:06 PM
Oilbrnr's Avatar
Default ETC Adjustment?
Wife's Magnum idles fine until you let your thumb off the throttle. Is there an adjustment in the ETC to prevent this, or does the whole thing need to be replaced?
Old Mar 13, 2008 | 05:09 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if theres no play in the throttle(about 1/8") then it needs to be adjusted. yes theres an adjustment.
Old Mar 13, 2008 | 05:14 PM
Oilbrnr's Avatar
There is about an 1/8th between shutdown (no thumb) to where RPMs just start to increase, i.e. slack.
Is the adjustment inside the ETC? If so, does the cover just pop off? I really didn't spend much time looking at it last night...
Old Mar 13, 2008 | 05:40 PM
Rowe's Avatar
not sure about yours but my sportsman has an adjustment on the cable. There is a rubber boot just slide it up and youll see the adjuster. Loosen the lock nut and adjust it so there is about 1/8" of freeplay at the thumb throttle. You'll probably find that the locknut loosened up from vibration and backed out a little. I had to adjust mine just the other day.
Old Mar 13, 2008 | 05:50 PM
Oilbrnr's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Rowe
not sure about yours but my sportsman has an adjustment on the cable. There is a rubber boot just slide it up and youll see the adjuster. Loosen the lock nut and adjust it so there is about 1/8" of freeplay at the thumb throttle. You'll probably find that the locknut loosened up from vibration and backed out a little. I had to adjust mine just the other day.</end quote></div>
Cool, I'll look at that tonight, but wouldn't that just effect the freeplay in the cable vs. the electronic shutdown of the ignition?
Old Mar 13, 2008 | 06:51 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
there is such a thing as too much play and not enough that will make etc kick on and shut down the bike. like rowe said you adjust it on the cable.
Old Mar 13, 2008 | 11:12 PM
furnaceman's Avatar
I had the same problem on my 96 you should adlust at the cable behind the rubber sheild. I had to play with mine a bit lke the guys said too much and too little can cause it to kick in/ shut down.
Bill
Old Mar 17, 2008 | 01:19 PM
Oilbrnr's Avatar
Thanks guys! A quick adjustment of the cable, and she is idling fine now! I'm glad it was that easy...
Old Mar 17, 2008 | 03:35 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
glad some of the information we gave you helped get you up and going again. ride safe.
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
r1pilot83
Sep 27, 2015 07:38 PM
