Wheels - X2 versus Sportsman
Old Mar 14, 2008 | 10:38 PM
bad87gn's Avatar
Default Wheels - X2 versus Sportsman
Anyone know the differences for sure? Seems that the X2 have more backspace so that the quad is narrower. I was wanting to swap wheels between my two before selling the Sportsman.
Old Mar 15, 2008 | 01:48 AM
reno82's Avatar
They are different according to the part numbers, but the book doesn't list backspace. Why not just measure the two and see what the difference is.
Old Mar 15, 2008 | 09:04 PM
firehog's Avatar
I put my wheels from my sp800 deluxe on my sp700x2.....the front backspacing was identical and the rear was 1/2" wider. Keep in mind the stud bolts are shorter for steel wheels, so you may need to put in longer stud bolts for the aluminum wheels (easy fix). I hope this helps....
Old Mar 18, 2008 | 01:29 PM
OIown12's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: firehog
...Keep in mind the stud bolts are shorter for steel wheels, so you may need to put in longer stud bolts for the aluminum wheels (easy fix). I hope this helps....</end quote></div>
^ Not true. I have an 07 X2 500. I replaced the 12X6 front and 12X7 rear stock steel wheels with 12X7 aluminum all around. Stock wheels used flat lugs and aluminum wheels used fluted lugs on the same studs. I bought Vision wheels (the same company that makes the aluminum wheels for the Polaris Deluxe models). Almost all Polaris wheels have a 4/156 bolt pattern and a 4+3 offset.
Old Mar 18, 2008 | 03:53 PM
firehog's Avatar
Hmmmm....well all I can say is I tried the "fluted" lugs with the aluminum wheels and they did NOT work, stud bolts too short. Hence, the need to install longer stud bolts. Maybe yours already had longer bolts? If your machine came with aluminum wheels, then it would already have the longer stud bolts.
Old Mar 18, 2008 | 04:03 PM
OIown12's Avatar
^ It didn't.
Old Mar 18, 2008 | 10:10 PM
bad87gn's Avatar
Well, I swapped them and agree with firehog. My SP 500 definitely has shorter studs than the X2. Both quads seem OK, though the SP wheels are only on by maybe 4-5 turns of the lug nuts - should be OK I think.
Old Mar 18, 2008 | 10:24 PM
firehog's Avatar
Yeah, that's the problem I had. When I tried to torque them down, they would just spin since the stud bolts were a little too short. I would be sure they are torqued to 90ft lb. Otherwise, you risk losing a wheel....
Old Mar 18, 2008 | 11:53 PM
sheepdogMSP8117's Avatar
When I swapped my 800 Deluxe rims to my 500 H.O., the studs on the 500 were not long enough for the wider aluminum rim's mounting area. I had to replace the 500 studs with the longer studs of the 800 in order for the swap to work.
As far as the backspacing, I don't know if its the same from Sportsman to X2.
Old Mar 19, 2008 | 12:24 AM
reno82's Avatar
Hey sheepdog, how do you like the 14" rims? I do mostly trail and rock crawling and I'm thinking I'd be better with a taller tire on 12" wheels, but I sure like the looks of the 14's. What size terracross tire do you have on those, and did you have to use spacers?
Jmuddin284
Jan 19, 2026 07:16 AM
Big bousse
Sep 26, 2015 10:42 AM
Schneider
Jul 24, 2015 05:05 PM
Jul 21, 2015 03:03 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
