82 atc front fender rubbing!! how to fix
Old Mar 17, 2008 | 11:40 AM
notyepcars's Avatar
Default 82 atc front fender rubbing!! how to fix
I have a 82 honda atc 70 that has the rubbing marks in the the front fender where it has hit the head while turning. Is this a frame problem? fork problem? How do I go about fixing it? Thanks
Old Apr 18, 2008 | 01:50 AM
SMFREY's Avatar
You can usually just bend the fender they do get pushed back and can hit the head bolts
The forks could also be bent if they are not bad
I would just see if you can move the fender in the holes
You may have to elongate the lower holes to move fender away
Good luck
Ray
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
cSchwartz
Technical and How-To Articles
Jul 10, 2015 08:06 PM
