Need Help-250x clutch
Old Mar 18, 2008 | 03:23 PM
dan92's Avatar
Default Need Help-250x clutch
i am putting a new motor in my brothers 250x. i got it in and running but the clutch wont disengage. the cable is good and i adjusted it to max so it pulls the arm on the motor all the way. i have no idea what is wrong. any help would be great asap. he wants it done soon.
Old Mar 18, 2008 | 03:50 PM
pmcc37's Avatar
the spline that comes out and pushes the clutch may not be set all the way back in the socket. on the outer case.
Old Mar 18, 2008 | 04:05 PM
dan92's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: pmcc37
the spline that comes out and pushes the clutch may not be set all the way back in the socket. on the outer case.</end quote></div>
how do i fix that. do i just pull the cover off and adjust it.
Old Mar 18, 2008 | 04:21 PM
pmcc37's Avatar
yea, pull it off and make sure it sits all the way back. then slide the rod down next to it and put it back on.
Old Mar 18, 2008 | 04:29 PM
dan92's Avatar
thanks. i'll check it out when i get home.
Old Apr 1, 2008 | 11:06 PM
dan92's Avatar
well i took it apart and looked at the arm or spline deal and it looks fine. i put it back together and it still doesn't work. i ave another 250x and when i pull on the cultch levers on both of them the arms on the motor are in the same spot on both quads but only my quad disengages the cluch. anymore help would be great.
Old Apr 2, 2008 | 07:36 AM
HondaMechanic's Avatar
If the motor's been sitting a while the clutch plates maybe stuck ..
Old Apr 2, 2008 | 02:38 PM
dan92's Avatar
i think its been sitting for a year after it was rebuilt. i'll check the plates. how does the clutch disengage in these things?
Old Apr 2, 2008 | 11:20 PM
dan92's Avatar
well i checked the clutch plates and pulled them apart and put it back together and it still doesn't work. i dont get it. any help would be great.
Old Apr 3, 2008 | 07:20 AM
