Wolverine 450 - top speed & dynojet ???
Old Mar 19, 2008 | 10:03 AM
max77's Avatar
Default Wolverine 450 - top speed & dynojet ???
Hi !
Top speed for my Wolvie was 83 km/h (stock)
After installing DynoJet kit top dropped down to 79-80 km/h...
WHY ??? any ideas ?
Old Mar 19, 2008 | 10:19 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
Must be too rich.
Old Mar 19, 2008 | 11:12 AM
yotatrailrunner's Avatar
or too lean, you need to jack up the rear, run it wide open for 30 seconds, and shut the ignition off and bring the tires to a stop as quick as you can. then pull the plug and read it. there are alot of good places on the internet to help you read your spark plug.
Old Mar 19, 2008 | 11:16 AM
Koopa's Avatar
That's possible too. Usually if your too lean you get sum backfire too rich it'll feel sluggish. Jetting is something I wouldn't have messed with unless you added a pipe and/or changed up filter or airbox. You won't have much, if any, performance change if any from solely a jet kit.
Old Mar 19, 2008 | 04:18 PM
ss454's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Koopa
That's possible too. Usually if your too lean you get sum backfire too rich it'll feel sluggish. Jetting is something I wouldn't have messed with unless you added a pipe and/or changed up filter or airbox. You won't have much, if any, performance change if any from solely a jet kit.</end quote></div>
Exactly! Sounds like it's too rich. Just a hair lean is the best performance if I'm not mistaken.
Old Mar 19, 2008 | 09:27 PM
ich4bdm's Avatar
try taking the baffles out of your exhaust and take air box lid off. should make a little difference. my brother in law has an 07 459 wolvy and he put a k&n on it. seems to be runnin a little faster.
Old Mar 20, 2008 | 04:05 AM
max77's Avatar
right, i'll try running to the max w/o air filter... Thanx a lot !
Old Mar 20, 2008 | 09:21 AM
Eimajz's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: max77
right, i'll try running to the max w/o air filter... Thanx a lot !</end quote></div>
I'd keep the air filter on, maybe run to the max w/o air filter lid.
Old Mar 22, 2008 | 10:23 PM
ich4bdm's Avatar
I said AIR BOX LID,
Old Mar 22, 2008 | 11:48 PM
miw0lvi450's Avatar
a hauck clutch kit will fix that right up =)
2007 yamaha wolverine 450 SE
2004 yamaha blaster
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
