Inside headlight/speedo .Work light wiring.
Old Mar 19, 2008 | 10:39 PM
markss396's Avatar
Default Inside headlight/speedo .Work light wiring.
I recently opened my headlight/speedo on my 07 800 ,Can anyone tell me which wires i would use to wire in the work lights? Also what is the 9V battery clip in there for? Is it to hold the clock when you un hook the Batt.?
Thanks for the help.
Old Mar 19, 2008 | 10:46 PM
reno82's Avatar
I have a plug sitting disconnected under the headlight pod on my "08" I think it's the worklight wiring. I have work lights on the back but no bulb or switch. When i get a chance I'm going to try and add my own switch. I think everythig is there but the bulbs and switch.
Old Mar 19, 2008 | 10:50 PM
JCDEYO25's Avatar
The 9V connection is used to test the throttle position sensor.....
John
Old Mar 19, 2008 | 10:55 PM
badazzpred's Avatar
I just hooked mine up.The un-used plug is for the work lights.and the 9V battery connection is for diagnostics
Markss396 you should have the same set-up
Old Mar 20, 2008 | 12:06 AM
markss396's Avatar
Thanks everyone , i will check it out.
Old Mar 20, 2008 | 07:30 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the plug end that you see in the pic. w. the spade connectors going in the differnt dierctions is the one for the work lights.
the wires are red and blue in the black plastic protector.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
poutlaw525
Sep 9, 2015 03:19 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
