Panther 110 not charging
Old Mar 22, 2008 | 10:30 AM
air4se's Avatar
Default Panther 110 not charging
I posted this in the wrong place I think the first time. We have a Panther 110 and the battery never charges. Is there suppose to be a charger on this thing or should I use a trickle charger?
Great site!
Thanks!!
Tim
Old Mar 22, 2008 | 11:30 PM
DeerForce1's Avatar
That is the same bike i got my son. It does have an on boaed charging system that should be able to keep a good battery charged. From what i have been told & seen the batteries are the weak link. You should have gotten a 110 volt battery charger with the bike (I got 1 with all 3 bikes) if you got 1 hook it up until the red light goes out & the green light comes on. It should have a good charge then. If it doesn't hold the charge replace the battery & you should be good to go.
Hope this helps............................................. .............DF1
Old Mar 23, 2008 | 03:39 AM
air4se's Avatar
Thanks, I took it to the shop and bought a new battery and a charger that is made for it. We will see. Thanks again for your help.
Tim
Old Mar 24, 2008 | 12:32 AM
flatblack's Avatar
How many wires are comming out of the stator side of the motor, that would be the shifter side?
Old Mar 24, 2008 | 06:12 AM
air4se's Avatar
There is no shifter on this one. There are 2 wires coming from the left side of the motor, I am assuming that is the magneto. I will put a tester on the battery while it is running to see if there is any charge at all coming out.Thanks for the reply!
Tim
Old Mar 24, 2008 | 10:21 AM
flatblack's Avatar
No need, you don't have a charge coil under the flywheel. You will need to install a charge coil and rectifier and maybe a new flywheel cause the one you have might not have the magnets for the charging coils in it.
That is why I left the ? at the end cause I was unsure if you have a CVT type motor
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
zPuls3
Sep 12, 2015 08:54 AM
