Baja 90cc atv push start and nothing
Old Mar 23, 2008 | 10:31 PM
simonquenton's Avatar
Default Baja 90cc atv push start and nothing
Have a Baja 90cc atv for my son. Good battery and push start and nothing, not even click. Checked safety kill in back-fully inserted. Almost as if it is not being recognized in neutral.
Can anyone help? Should I just be looking for salvage money at this point?
Old Mar 23, 2008 | 11:26 PM
hotblooded's Avatar
I am not familiar with the Baja 90, but I would just check over all the wires. We got to the races on Saturday and the Eton would not start. There was nothing, just like you described. I found one wire unplugged just behind the ignition switch and one under the tank on the right side that was half unplugged. Plugged both in and it was just like new.
Old Mar 24, 2008 | 12:09 AM
flatblack's Avatar
does the head light light up? if so the check the brake switch and the left kill switch will only kill the spark not the crank.
Look for a green with red stripe make sure it is NOT connected to anything unless it has a neutral lamp on the handle bars.
I have had to replace 3 wire harnesses with similar issues, some of the wires rub through and short the FUSE so check it too......let me know if this helps
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
Jun 15, 2015 11:22 PM
jayking232003
Jun 9, 2015 02:54 PM
Jun 8, 2015 06:45 PM
1000gade
May 27, 2015 12:37 PM
