Help with sp335 shifting
I have a SP 335 and it keeps popping out of forward high when I shift it in. I am using it to plow snow and when I go from rev. to low range it is fine. But when I try to go to high range the shifter pops back out sometimes. Is there a adjustment for this? What causes this? Any help would be appreciated. Thanks
snoman
There is two adjustment bolts on the shifter arm. Pull the plastic off on that side and you will see the shifter linkage. This can be adjusted so it will stay in gear. I have never had to do this, but I would imagine you would have to make the linkage a little longer so it will get it all the way into gear. Remember though that the linkage adjusters go the opposite way.
