18 grease fittings on a 02 500?
Old Mar 25, 2008 | 09:31 PM
RickCJ7's Avatar
Default 18 grease fittings on a 02 500?
I found 14 fittings and greased the 4 tie rod ends. Did I miss 4 fittings?
6 in the rear sus.
2 on front driveshaft
2 1 on each axle ujoint
2 1 each lower ball joint
2 front lower control arms
nothing on steering shaft
4 tie rod ends.
= 18
Old Mar 26, 2008 | 09:13 AM
Ujoint's Avatar
Starting from the front of the quad.....
Lower A arm pivot - - (Left & Right =2)
Axle U joint - - (Left & Right =2)
Ball Joint - - (Left & Right =2)
Upper Steering Shaft bushing
Prop shaft U joint (front)
Prop shaft U joint (rear)
Prop shaft slip joint ( tranny output)
Rear Lower Arm pivot - - (Left & Right =2)
Rear Upper Arm Pivot (front of CV joint, rear of CV joint) - - (Left & Right =4)
Rear bearing carrier (REMOVE Wheel to access) - - (Left & Right =2)
Equals 18
Old Mar 26, 2008 | 09:30 AM
RickCJ7's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Ujoint
Lower A arm pivot - - (Left & Right =2) yes
Axle U joint - - (Left & Right =2) yes
Ball Joint - - (Left & Right =2)yes
Upper Steering Shaft bushing none
Prop shaft U joint (front) yes
Prop shaft U joint (rear)yes
Prop shaft slip joint ( tranny output) didn't get
Rear Lower Arm pivot - - (Left & Right =2)yes
Rear Upper Arm Pivot (front of CV joint, rear of CV joint) - - (Left & Right =4)yes
Rear bearing carrier (REMOVE Wheel to access) - - (Left & Right =2) didn't pull wheels!Equals 18</end quote></div>
Old Mar 26, 2008 | 09:38 AM
Ujoint's Avatar
upper steering shaft bushing - - item #2
http://216.37.204.206/wps/Pola...asp?Type=13&A=251&B=48
Old Mar 26, 2008 | 10:42 AM
RickCJ7's Avatar
I saw a spot in the center of the top post bushing where a grease fitting could have been but it wasn't there and no easy way to get it.
I can't find anything on the rear bearing carrier either.
I did miss the slip yoke and got it!
So far 19
Old Mar 26, 2008 | 11:06 AM
Ujoint's Avatar
I finally got through to my dad - he owns an ATV repair shop (that I grew up in) - as I need to "borrow" his clutch tools.
He told me that on the 02's, there may or may not be the grease points on the rear bearing, since this is the year where they started transitioning to the "greaseless" ATV. He said you should be able to tell if it is greaseable by the bolts on the lower carrier pivots - 9/16 head bolt has the grease zerk, 5/8 head bolt does not.
EIF
Apr 20, 2017 07:15 PM
tysonbully
Sep 28, 2015 02:30 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
bigred20653
Sep 19, 2015 02:11 PM
bmark0610
Sep 7, 2015 09:42 PM
