18 grease fittings on a 02 500?
Starting from the front of the quad.....
Lower A arm pivot - - (Left & Right =2)
Axle U joint - - (Left & Right =2)
Ball Joint - - (Left & Right =2)
Upper Steering Shaft bushing
Prop shaft U joint (front)
Prop shaft U joint (rear)
Prop shaft slip joint ( tranny output)
Rear Lower Arm pivot - - (Left & Right =2)
Rear Upper Arm Pivot (front of CV joint, rear of CV joint) - - (Left & Right =4)
Rear bearing carrier (REMOVE Wheel to access) - - (Left & Right =2)
Equals 18
Equals 18
<div class="FTQUOTE"><begin quote>Originally posted by: Ujoint
Lower A arm pivot - - (Left & Right =2) yes
Axle U joint - - (Left & Right =2) yes
Ball Joint - - (Left & Right =2)yes
Upper Steering Shaft bushing none
Prop shaft U joint (front) yes
Prop shaft U joint (rear)yes
Prop shaft slip joint ( tranny output) didn't get
Rear Lower Arm pivot - - (Left & Right =2)yes
Rear Upper Arm Pivot (front of CV joint, rear of CV joint) - - (Left & Right =4)yes
Rear bearing carrier (REMOVE Wheel to access) - - (Left & Right =2) didn't pull wheels!Equals 18</end quote></div>
I finally got through to my dad - he owns an ATV repair shop (that I grew up in) - as I need to "borrow" his clutch tools.
He told me that on the 02's, there may or may not be the grease points on the rear bearing, since this is the year where they started transitioning to the "greaseless" ATV. He said you should be able to tell if it is greaseable by the bolts on the lower carrier pivots - 9/16 head bolt has the grease zerk, 5/8 head bolt does not.
