86 fourtrax 350 front master cylinder
Old Mar 27, 2008 | 09:01 AM
tycobb280's Avatar
Default 86 fourtrax 350 front master cylinder
I have an 86 fourtrax that has a bad front master cylinder. when i pump the brake it gets hard, but when i releaseit, the fluid shoots back up into the resevoir. is there a rebuild kit i can get for this? i was also wondering if i could use a master cylinder from something else, like another 4 wheeler, or motorcycle. i would think that anything would work as long as the fittings match up. thanks for the help?
Old Mar 27, 2008 | 10:03 AM
OIown12's Avatar
Cheap Cycle Parts has a master cylinder set for about $30.
Old Mar 27, 2008 | 10:21 PM
Double t's Avatar
i got one off a yamaha at the junk yard 5 bucks. works great. i think most atvs have the same size line
Old Mar 31, 2008 | 01:07 AM
KNOWSALOT's Avatar
The Facility
You want one new, buy one for the new 500 Foremans and Rubicons. Or the Rancher 420. You will have to buy a brake lever for the same model because yours will not fit the 500 master cylinder, but the whole setup including the lever is less than 75 bucks from your dealer because Honda is using a vendor from China on these pieces for the new Foremans and Rancher 420 models. I have been buying these to replace master cylinders on all types of ATVs for the past 2 years. They use the industry standard 10mm brake line bolt so they fit nearly everything out there.
Bratman2
Aug 6, 2022 01:42 AM
TLC
Jul 25, 2015 02:24 AM
Sandman2.0
Jul 21, 2015 09:03 AM
tporath
Jul 11, 2015 12:31 PM
