Does any ATV(Quad) have a proper rear differential?
Old Mar 27, 2008 | 11:35 AM
gerardthefarmer's Avatar
Default Does any ATV(Quad) have a proper rear differential?
In particular, Honda or Arctic cat.
Honda do not have a proper rear differential.
The rear axle is solid inhibiting tight turns.
Gets worse when towing a heavy load,
ATV does not want to turn.
A proper rear differential,
that could be locked when needed,
would be ideal.
Anyone?
Old Mar 27, 2008 | 01:15 PM
hondabuster's Avatar
Look for a quad with what is called a turf mode. Polaris has some models, and the older bayou 300s had it too.
Old Mar 27, 2008 | 01:19 PM
OIown12's Avatar
^ Yep, my Polaris X2 500 EFI. Doesn't affect the turning radius, just doesn't tear the grass up while turning.
Old Mar 27, 2008 | 01:52 PM
Kyforeman's Avatar
The old Yamaha Terra-Pro had a rear end that was also made like that. A Great little machine in its day. Check the link out for more info on them.
http://www.yamaha-motor.com/ou...88_terrapro_small.aspx
Old Mar 27, 2008 | 01:53 PM
Any of you know if Arctic Cat have this in the new 700D (diesel) or are they solid back axle like Hondas.
(BTY, I own a Rincon)
Thanks.
neilbedwell
Nov 10, 2018 11:02 AM
tweeder
Jul 5, 2015 01:57 PM
NLWarrior01
Jun 28, 2015 12:54 PM
VRRRRT
Jun 27, 2015 09:38 AM
Biggieshortie89
May 26, 2015 08:01 AM
