2006 Wolverine 450 running rich
Old Mar 29, 2008 | 12:34 AM
2006wolverine's Avatar
Default 2006 Wolverine 450 running rich
Hi, recently my wolverine has been running horrible. I pulled the plug and it was all carboned up. It runns better with the choke on at aprox 20 mph. And it runs aprox 10 mph with the choke off. Tell me what you guys think....Thanks
Old Mar 29, 2008 | 01:53 AM
hondabuster's Avatar
We need a better discription than it runs horible. Is it missing, bogging, breaking up, smoking? Did you change the spark plug....did it get better? How long since the air filter has been cleaned and reoiled?
Old Mar 29, 2008 | 10:01 AM
We are going to change the pulg. We think that there might be a obstructrion, or something is wrong with the choke/throtle cable. Are cables usually a big problem. It was bogging down once you went about 1/4 of the throttle pull. And when you pulled it all the way it would backfire sometimes.
Old Mar 29, 2008 | 12:01 PM
The cables should be fine. Pull the float bowl off the carb, and check for crud, then check the main jet for an obstruction. If you find lots of crud in the float bowl, then think about adding an in line fuel filter.
Old Mar 29, 2008 | 04:10 PM
I took off the carb and I took off the top thing( the black thing inside the carb that goes up and down, I think its the throtle valve) and relubed and cleaned everything. Wasn't bad. So I will take out them float bowl and inspect it. My dad thinks that something is blocking the airway some how. IT is still bogging down when I pull the throtle more then 1/4 the way. Any help is appreciated.
Thanks
Old Mar 29, 2008 | 05:16 PM
That means the main jet is plugged. Youre gonna need to take off the float bowl, and remove the jets, and clean the crud out of there.
Old Mar 29, 2008 | 08:53 PM
ctateusa1's Avatar
common problem on the wolvy due to a poorly located vent tube, with no check valve on the bottom of it. after you clean the jets relocate the vent tubes on the carb up by the airbox to prevent it from happening again.
Old Mar 30, 2008 | 12:37 PM
Cmarti's Avatar
I just had a problem with a BearTracker. Not running as bad as what you describe, but had a stumble off idle and trouble with the enrichener/choke.
Cleaning the carb did not help, but I went back in and the float level was way off. Hondabuster set me in the right direction.
(BTW thanks HB)
Old Mar 30, 2008 | 11:37 PM
Thanks guys I will deffently do all these things..
suzuki230
Jul 8, 2016 10:03 AM
Nelson
Jun 22, 2015 03:51 AM
Nelson
Jun 20, 2015 01:59 PM
robj
Jun 15, 2015 08:45 PM
Joe Paul
May 27, 2015 09:04 AM
