97 Scrambler 500
Old Mar 29, 2008 | 07:37 PM
Rowe's Avatar
Default 97 Scrambler 500
So I jump on my wifes Scrambler today to climb a hill, well I get about 1/2 way up and clunk, clunk, clunk. It sounds like its coming from inside the belt cover almost like its jumping teeth on the sprocket. I dont know anything at all about these cvt's and such. It did it going up the hill and also when I hit the throttle pretty hard. Any idears?
Old Mar 29, 2008 | 07:42 PM
TLC's Avatar
TLC
A 97 ? maybe time to change the belt.
Old Mar 29, 2008 | 07:55 PM
Rowe's Avatar
If it were a bad belt would it make this noise. It is a really loud and sounds horrible. I used to have a Honda 250x and one time I broke a couple teeth off the sprocket and this is what it reminds me of.
Old Mar 29, 2008 | 09:25 PM
TLC's Avatar
TLC
A shredded belt flopping around will make some horrible noises.
Old Mar 29, 2008 | 11:35 PM
ftwflh's Avatar
Check the belt first then the front drive sprocket.If those are good it is time to pull the tranny and replace the silent chain inside the gearcase.
Old Apr 21, 2008 | 08:28 PM
tsst's Avatar
What did this end up being? I have a similiar issue and mine sounds like it is coming from the gearcase. I am guessing the silent chain as it only happens in forward gear.
Old Apr 21, 2008 | 09:52 PM
Rowe's Avatar
It was the front sprocket of the rear drive. All the teeth were worn down and the chain was skipping.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
