1995 Polaris Trail Boss 250 Shifter
Old Apr 3, 2008 | 12:36 AM
rjestes3's Avatar
Default 1995 Polaris Trail Boss 250 Shifter
I bought a 1995 Polaris Trail Boss 250 2X4. After some cleanup and a carb kit the motor runs great, but it is difficult to shift from N to R or from N to F. About half way between shifter slots, the gears grind before dropping into gear. Suggestions please.
Old Apr 3, 2008 | 07:51 AM
ftwflh's Avatar
Check the alluminum arm on the tranny that the shift rod hooks to
Old Apr 3, 2008 | 09:17 AM
bullpark1956's Avatar
JUST MY 2 Cents whats ur idle at maybe a little fast i had one do that on a 95 and the idle after carb rebuild was set to high and once it was adj right it worked just fine
Old Apr 3, 2008 | 10:13 AM
rjestes3's Avatar
Thanks for the advice. I have the ATV idled a little high at the moment and slowing the rpm might help.
In the meantime, I found a severe crack in the shifter mount where it attaches to the vertical frame post. I made a new one from black pipe with a brass sleeve to serve as a babbit bearing. I had to change its mounting position slightly when I reattacjed it to the frame and may now have altered the length of the shifter connecting rod.... a little fine tuning may be required.
Regards, Jim
Old Apr 3, 2008 | 06:54 PM
Good deal gotta keep the ol machine running to have FUN
Ean
Dec 19, 2022 08:48 AM
Nondem
Feb 22, 2020 12:20 PM
Gtsordo
Jul 13, 2015 10:38 PM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
