YFZ 450 Problem
Old Apr 9, 2008 | 01:21 AM
jlinstrument's Avatar
Default YFZ 450 Problem
hello, i just bought a 2007 Yfz and im having a problem, its runnung way to lean, its back firing, and it cuts out for a sec when you hammer the throttle, i have like 2 hrs on the machine, its this a commen adjustment or dirty carb or something? anybody elese having this problem?
Old Apr 9, 2008 | 09:52 AM
Hebs's Avatar
depending on elevation and humidity... your jetting could be off from the factory... buy some jets and see how they work for ya...
Old Apr 10, 2008 | 09:10 AM
ohyeahfriday's Avatar
Hebs is probably right, these machines can be a little finicky when it comes to jetting...
Old Apr 10, 2008 | 12:49 PM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
lol..."its running way to lean" you answered the question right there, jet it up
Old Apr 10, 2008 | 02:14 PM
pmcc37's Avatar
the 07's come with a blockoff plate to the air fuel mixture srew. take it off, go buy a msr replacement $20 that comes out the bottom and allows you to adjust it wth your fingers. Run it out until you get the best throttle response then come back in a 1/4 a turn and ride it to see how it does.... Your problem should then be solved if everything is stock.....
the 04-06's didn't have it blocked off but for some reason the genusius at yamaha decided to put it on the 07'...
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
