20x11-9 or 22x11-9?
Old Apr 10, 2008 | 05:02 PM
Poopie32's Avatar
Default 20x11-9 or 22x11-9?
I have a 1997 300ex and I need to decide what size tire I want. Stock tire size for the 300ex is a 22x11-9, but I know the 400ex runs the 20x11-9. What do you guys think? I'm looking to purchase the Maxxis Razr's because I currently have those in the front. Let me know please...thanks!!
Old Apr 10, 2008 | 05:33 PM
DWill58's Avatar
If you want it to look "sporty" then get the 20's, if you want more of a "utility" look then go with the 22's.
Old Apr 10, 2008 | 05:55 PM
Poopie32's Avatar
Yeah, I can tell the difference. But as far as performance and everything else goes what do you suggest? I currently have it rejetted with a WB pipe, and a new air filter. But that's about it. My last set of tires were the Pure Sport Realtors which are basically paddles and they were 22 and they seemed huge...
Old Apr 10, 2008 | 07:40 PM
DWill58's Avatar
Just because they say 22, not all 22's (or 20's for that matter) are exactly 22" including the tread. They all vary depending on how the manufacturer measures their tires. Performance wise, you'll get a little more torque out of the smaller tires since they'll turnover faster, but you'll give up a little top speed.
Old Apr 10, 2008 | 09:47 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I have run both Holeshot XC's (22" front/20" rear) and XCT's (23" front/22" rear). The XCT's are nice because they increase ground clearance, but you lose bottom end power because the effective gearing is raised (but a change in gearing can fix that). The XC's are nice because it just handles better (lower center of gravity) and the steering is quicker.
Personally, on the little EX I would go with the XC's, and give up a little ground clearance for a little more low end power and better handling.
Old Apr 11, 2008 | 05:49 PM
Poopie32's Avatar
Thanks alot for the information reconranger...very helpful information!!
bberck
Mar 28, 2005 10:48 PM
Baja2002
Nov 7, 2004 06:55 PM
MinnDS650WOW
Mar 27, 2004 01:51 PM
2000_Warrior_350
Oct 28, 1999 10:27 PM
