warrior not cranking over
Old Apr 13, 2008 | 03:37 PM
tiffann87's Avatar
Default warrior not cranking over
my fiance's and my 1998 warrior was running fine until we shut it off for like 5 minutes and then tried to start it up again and it didnt crank over...it does nothing, it doesnt click or make any noise at all.... it kind of acts like there is no key in the ignition...this happened to us once before but it eventually started again within like 2 minutes of it not starting...does anyone know what is wrong with it or what it could be???
Old Apr 13, 2008 | 03:59 PM
cms10balla's Avatar
check to see if ur wire terminals are tight on the battery
Old Apr 13, 2008 | 04:47 PM
tiffann87's Avatar
we checked all the wires and made sure that they were all tight
Old Apr 13, 2008 | 05:06 PM
StngGT350's Avatar
i had that happen to me once on my wife;s warrior in the middle of the mountians. i ws like Crap! but i found a terminal loose on the solnoid which is above the left rear tire loose. you can jump it across and your bike should start. if it does not i would look at your starter or battery. good luck
Old Apr 13, 2008 | 05:20 PM
tiffann87's Avatar
haha thats what happened to us, but we had a friend with us who pushed us, and we got it push started... but my fiance is on his way home from work, so we will probably check that when he gets home...thanks!
Old Apr 13, 2008 | 06:23 PM
QWODER's Avatar
have you checked the fuse.I believe it is on the frame under the seat or rear fender.Maybe someone else can help with its exact location.
Old Apr 13, 2008 | 07:29 PM
tiffann87's Avatar
yupp thats what it was..thanks a lot, we would have never thought of that!
Old Apr 18, 2008 | 03:07 PM
Lthrneck's Avatar
Where did you have to buy the new fuse at? My warrior sat for quite a while since I was deployed overseas for the last 7 months. (Marine Corps). The battery was dead so i jumped it off with my car to get it started now it will not start. When I turn the key on you can hear the relays that are back by the solenoid chattering so to speak. I have already replaced the 20 AMP fuse so that wasn't it. If you guys think I am looking at the worng thing please chime in. Getting my butt kicked on this one.
Semper FI
Lthrneck
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Jackg17
Sep 26, 2015 09:30 PM
Bernhard
Sep 25, 2015 12:45 PM
