2WD Or 4WD Indicator
Old Apr 16, 2008 | 11:48 AM
Perales's Avatar
Default 2WD Or 4WD Indicator
I Just Noticed This Today While Putting My Brute Force 650 4x4I, In To 4x4 The Indicator Showing 2WD Wont Change To 4WD I Know Ur Suppose To Go A Couple Of Feet Before It Engages I Dont Know If Its Ingaging Or Not, I Dont Know What Might Be The Problem If Theres A Problem Will The Warranti Cover It Its Brand New It Only Has About 11 Hours In It
Old Apr 16, 2008 | 12:50 PM
Hayashi's Avatar
I assume the indicator is not flashing anything. Then, jack up the ATV in air, give a little in 4WD and watch if front wheels are turning or not. Most likely not. Also, see if you can hear the sound of servo motor (actuator) turning or not. Most likely not. If both is negative, you have an electrical/electronic issue, not mechanical. Dealer should repair under warranty.
95wolv
Sep 27, 2024 12:00 PM
speedbuff
13
Nov 11, 2020 10:16 AM
Clint Russell
Sep 25, 2015 03:20 PM
bigred20653
Sep 19, 2015 02:11 PM
Schneider
Jul 24, 2015 05:05 PM
