2000 450 ES won't downshift! Help please!
Old Apr 17, 2008 | 01:22 AM
caribouhunter's Avatar
Default 2000 450 ES won't downshift! Help please!
Hi everyone, I see another topic about a honda not shifting but I don't want to hijack his thread, so I started a new one. Here is my problem, 2000 450 es just decided one day not to down shift. I can shift it with the manual lever, and every once and a while (when I was trying to diagnose) would complete a shift. When I was driving it and the downshift quit, I could hear it trying to downshift and the rpms would drop alittle, but just would not go to the lower gear. Any suggestions?
Old Apr 17, 2008 | 03:22 AM
TLC's Avatar
TLC
Do you mean it will shift up though? My 450es was stuck in 2nd (No up or Down) and I pulled off the seat and cleaned and checked every fuse and connection and it worked fine again.
Old Apr 17, 2008 | 07:17 AM
HondaMechanic's Avatar
Did you first adjust the clutch ..
Old Apr 17, 2008 | 05:31 PM
I have adjusted the clutch already, it was one of the first things i tried. it upshifts with no problems but will not downshift. i checked for power to the angle sensor, and removed the angle sensor and checked to verify that the resistance changed smoothly when the angle sensor was turned. it is ok. I will admit that I did not disassemble the switches on the handle bars. Are the switches easy to disassemble and clean?
Old Apr 30, 2008 | 05:28 PM
mbrowning's Avatar
I had a problem with my machine shifting intermittingly until finally it would not shift at all from 4th to a lower gear. The manual shift would not work either.
I have had my machine for 4 years and had not done anything to it except drive it.
If you have not changed oil lately I would do that. The engine and transmisson all use the same oil on mine.
Hope you figure it out.
Old May 4, 2008 | 03:20 PM
cody_lyons78's Avatar
there has to be a short in the angle sensor mine had the same problem
07' honda Foreman ES
27' Maxxis Bighorns onITP ss108s
warn xt30 winch synthetic cable
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Clint Russell
Sep 25, 2015 03:20 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
