Hawkeye Clutch upgrade
Old Apr 17, 2008 | 08:17 AM
Dalehawk's Avatar
Default Hawkeye Clutch upgrade
Has anyone upgraded their performance on their 2006 Hawkeye? I am interested in removing the weights from my clutch but I have a couple of questions. Do you need the t-tool to do it? and where do you order the rollers?
Thanks,
daleontap@yahoo.com
Old Apr 17, 2008 | 09:32 AM
TennesseeTider's Avatar
You do not need the T-tool but it helps. Order 8 of the 12g (red) rollers from your polaris dealer provided that you are at low elevations.
Old Apr 17, 2008 | 12:39 PM
Hawkman300's Avatar
u dont have to buy new clutch rollers, just take out 2 opposing rollers and that works but takes off about 5mph top end.
Old Apr 17, 2008 | 09:17 PM
jokout's Avatar
I think Tider and I agree that it is much better to go with the full set of 8-12gm rollers...In my experience removing the 2-14 gm rollers was a bit to much weight to remove and tended to miss match the clutch and engine power curve causing the engine to over rev.
Another consideration is the size of the tires you are running...bigger/heavier tires will work better with lighter clutch weights
It's your decision to make, it seems that the Hawkeye's performance varies somewhat from place to place and owner to owner, you can try removing two opposing rollers and see how it works for you...you can always order the 12 gm roller set if you aren't happy.
8x14gms= 112gms total ('06 stock)
8x13gms= 104gms total (07 stock)
6x14gm = 84 gms total (2 rollers removed)
8x 12gms = 96gms total
Old Apr 17, 2008 | 09:25 PM
jokout's Avatar
also, if you need a little direction with the clutch mod our own RickyParker has posted some great videos on this on U-tube...here are a couple links to the vids. Have fun!
clutch cover
http://www.youtube.com/watch?v...qLNKo&feature=related
clutch roller mod
http://www.youtube.com/watch?v=WgQ5btcmztc
Old Aug 29, 2010 | 01:57 PM
fordfanatic69's Avatar
Why did you remove the videos form you tube?
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
snowolson
Aug 31, 2015 03:51 PM
