OK, I have a question now... Stabil
Old Apr 17, 2008 | 03:22 PM
Gimpster's Avatar
Default OK, I have a question now... Stabil
When Stabil is left in fuel too long, it forms beads and a jelly like bead compound.
Then after it sets like this for a while it gets hard causing chunks of dried beads.
I need to know what will break this stuff down
I have a tank filled with this stuff and can't break it down.
I have tried :
- Fresh Stabil
- Carb Cleaner
- Carb dip
- Mineral spirits
- Paint reducer for acrylic paint
- Gas
- Diesel
- Toulene
- Xylene
... to soak this stuff
WHAT IN THE HECK BREAKS THIS STUFF DOWN ??
help
----- Gimpster -----
Old Apr 17, 2008 | 03:44 PM
DWill58's Avatar
Considering the list that you've gone through, I would say nothing, lol.
Old Apr 17, 2008 | 04:29 PM
tramp's Avatar
Gimpster
Try "Techron" concentrate fuel injector cleaner by Chevron. Be sure and get the concentrate. It is amazing stuff. I have even used it to clean the sticky fuel gauge float in my diesel pick-up, when it sets too long with a full tank. I use it in my other vehicles twice a year for injector and fuel system cleaning. It says it is safe even for 2-stroke though I haven't used it in my snowmobiles. For them I use Sea-foam.
Old Apr 17, 2008 | 06:11 PM
Gimpster's Avatar
Heck, I'm going to try some sea-foam. I have some here, just never dawned on me to try it.
I'll see what it does
Old Apr 17, 2008 | 06:19 PM
700 sportsman's Avatar
pull the tank off and dump the gas and somehow scrape it out
Old Apr 17, 2008 | 06:45 PM
scootergptx's Avatar
Supersock
Hired Gun!
If all else fails, one these
And one of these.
Old Apr 17, 2008 | 07:17 PM
Williebee's Avatar
Glimpster the Sea Foam should disolve the staybil , but i would remove the tank and pour out as much as you can of the old fuel ; then pour some Sea Foam into the tank and pour some fresh fuel into the tank !
Then it will take an overnight soaking with the Sea Foam , the Sea Foam will disolve it ; it will just take over night to do it the stabil mixed fuel is suppose to be drained when stored from one season to the next that's why i use the Sea Foam now instead of the stabil !....
Old Apr 17, 2008 | 07:46 PM
Williebee's Avatar
Uhhhhhhhhh . Scooter that look's like it would disolve anything instantly alright ; but i think i would try the Sea Foam first i believe it will do the job it'll just take longer though !....
Old Apr 17, 2008 | 08:33 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Gimpster, How long did it take for the Stabil gas to turn to dried beads?
Old Apr 17, 2008 | 10:21 PM
action450s's Avatar
I used Stabil in my skidoo one winter only about 2 years ago put it in in April, stored the sled until November. By that time the gas/stabil turned to gel in the carbs and would hardly run at all. Had to completly dissassemble both carbs to clean and flush the tank and lines. I have never used Stabil in the sled previously or since then, and have never used it in the bike with no ill effects.
I just store said vechicle with what ever gas was left in the tank (typically under 1/4 tank - tanks are plastic) then on the first run I top off the tank with fresh supreme gas and 1/2 bottle of carburator cleaner that you mix with the gas. Never had a problem in 10 years following this procedure, for kicks I took the carb apart on the bike and found it squeaky clean like the day it was made!!!
