Timing Chain
Old Apr 19, 2008 | 01:36 AM
jkoss42's Avatar
Default Timing Chain
Im about to change a timing chain on a honda recon and was wondering if a clutch puller is needed, and if it is where can you get them. Are there any websites that sells them?
Old Apr 19, 2008 | 07:06 AM
HondaMechanic's Avatar
Yes the manual & centrifugal clutches must be removed to replace the cam chain .. .Be careful NOT to pull the camshaft out to far while replacing the chain unless you have the head and cylinder removed ..
Old Apr 19, 2008 | 10:33 AM
Ujoint's Avatar
We use a regular 2 jaw puller ( free "loaner" is available at your local Autozone) to pull the centrifugal clutch (sometimes the puller is not needed as a good "******" takes it right off the shaft - but for the most part, the puller is needed). The manual clutch will slide right off after you remove the nut.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Sjrpp
Jul 5, 2015 09:04 PM
