idleing problem
Old Apr 20, 2008 | 11:50 AM
vinman18's Avatar
Default idleing problem
i have a 98 trailboss 250 2 stroke and when it first starts, it idles fine then after i drive it for about 10 minutes or when it starts to get hot, it will only idle for about 10 seconds than it will idle down lower and lower and finally it will die. do i need to turn up the idle or is this a air flow problem?
thanks for any help
Old Apr 21, 2008 | 12:14 AM
vinman18's Avatar
it is also dosent like to start when its hot. does anybody know what might be causing this any help would be greatly appreiciated.
Old Apr 21, 2008 | 10:17 AM
Ujoint's Avatar
Sounds like a rich fuel problem, especially the "after it warms up" part - possibly even the choke valve is not set correctly, allowing the choke valve to be a little bit open all the time.
Old Apr 21, 2008 | 01:57 PM
vinman18's Avatar
What can i do to check these things, and what do you mean by a rich fuel problem.
Thanks for the reply.
Old Apr 21, 2008 | 08:35 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
make sure the float is set right and not sticking.
Old Apr 21, 2008 | 08:38 PM
Kerbbirds's Avatar
Turn the air fuel screw out a half a turn, if it gets worse go in a half.
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
MNatv89
Jul 7, 2015 11:36 AM
