2007 420 rancher
Old Apr 21, 2008 | 05:29 PM
theclown's Avatar
Default 2007 420 rancher
My rancher will not go into gear at times, especially reverse. But, if I take the screws loose on the on the assembly and spray WD-40 in there and let it set it will begin to work on the forward gears. It is hit and miss with reverse and sometimes I have to reset the machine.
Anyone had this problem and/or know how to fix it, short of buying a new assembly?
Thanks
Old Apr 21, 2008 | 06:00 PM
jrafter's Avatar
have you tried distalic grease instead of of wd-40...on the controls and the angle sensor
also how did you get the shifter thing open i was going to do the same thing as you put with grease
mine shifts most of the time but i have problems to
Old Apr 21, 2008 | 06:40 PM
HondaMechanic's Avatar
Does the gear shift indicator flash a code..?
Old Apr 21, 2008 | 07:03 PM
jrafter's Avatar
hey hondamechanic i know this is a dumb question but i cant seem to get the shifter controller apart do you know what page its on in the manual
Old Apr 21, 2008 | 07:54 PM
theclown's Avatar
I have not tried the grease, is it fairly easy to find? It does flash a code.
As far as getting the assembly apart, I just loosened the screws and pried it apart with a screwdriver far enough to get the spray nozzle of the WD-40 in there.
Old Apr 21, 2008 | 09:00 PM
If you mean the up/down shift buttons they are sealed and don't come apart ...
Old Apr 21, 2008 | 09:04 PM
jrafter's Avatar
ok
Old Apr 23, 2008 | 09:38 AM
theclown's Avatar
The N on my 420 is flashing 4 times and then 2 times quickly, any ideas what that tells me.
Thanks!
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
Sep 23, 2015 06:23 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
