front hub coil?
Old Jan 20, 2001 | 05:08 AM
real4x4's Avatar
the winding of wires that are inside the front hubs.how much does that coil of wires cost??i had to change the front hub seal and and the sleeve that the seal rides on that covers the coil and i pulled a few wires out while removing the sleeve.i fixed it back but if it isnt too expensive i will buy it new.whats the easiest way of removing the sleeve??
Old Jan 21, 2001 | 03:20 AM
Dazed's Avatar
I just priced one it was under 20.00 Bucks The best way to remove the sleeve is to cut it off crosswise with a small die grinder BE CARFULE DO NOT TOUCH THE INNER SLEEVE!!!!!!!!!!!!!!!! If you do go buy a new strut housing. Hope that helps
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
TheHood
Aug 8, 2015 05:49 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
chammerbeck
Jul 17, 2015 08:06 AM
tporath
Jul 11, 2015 12:31 PM
