Rear spring
Old Apr 25, 2008 | 11:49 PM
Tag75's Avatar
Default Rear spring
Where would I get a spring and what spring should I get for the rear of a 2000 Honda 300ex. My brother is just too heavy for the current one at around 265. The rear currently bottoms out and sags even on the hardest setting. So I am needing a bigger spring.
Old Apr 26, 2008 | 07:01 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default Rear spring
Call WorksPerformance....
But...when you change the spring rate the valving won't be correct anymore, so it will need to be revalved. Not sure if that is even possible with this unit (may not be rebuildable).
If you are serious, might have to spend the money on an aftermarket shock.
Old Apr 26, 2008 | 10:23 AM
Tag75's Avatar
Default Rear spring
Have any info about the place you are calling WorksPerformance?
Also which shock should I think about if i go aftermarket?
Old Apr 26, 2008 | 11:58 AM
Red Rider
Default Rear spring
http://www.worksperformance.com/
I suggest them if you have to go aftermarket. I have had their shocks on my 400EX for 10 years now, and they have been superb! Spend the extra money to do the front too.
On the other hand, the little 300 is an intro bike, and rather than pumping money into it, why not step up to a 400 instead???
merryman
Jan 19, 2016 04:29 AM
brinkkl2000
Oct 16, 2015 11:08 AM
Polaris5
Aug 29, 2015 09:11 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
