DOES ANYONE KNOW AN EASY WAY TO REMOVE A TIE ROD ON A KFX400
Old Apr 28, 2008 | 07:42 PM
clutchoo7's Avatar
Default DOES ANYONE KNOW AN EASY WAY TO REMOVE A TIE ROD ON A KFX400
I HAVE A 05 KFX 400.I ROLLED THE QUAD AND BENT THE STEERING STEM.I AM REPLACING THE STEM MYSELF,BUT HAVE NO CLUE ON REMOVING THE TIE ROD FROM THE STEERING STEM.ANY SUGGESTIONS WILL HELP,THANKS.....
Old Apr 29, 2008 | 09:26 PM
Bonedaddycjh's Avatar
Its really not that hard just a cotter pin and a nut. If you are replacing them you are better off replacing them both at the same time. Samething happened to be if they are older then when you go to put them back on they start to spin and you cant get the nut tight. Also, make sure that your tires are both hitting even.
Old Apr 29, 2008 | 09:51 PM
labguy's Avatar
Just stand the quad up by propping it on the back grab bar and pull the cotter pins, unbolt it from the stem and unscrew it from the ends and youre done.
antiguogrumete
Sep 5, 2015 03:41 AM
Dan Newberry
Aug 30, 2015 09:42 AM
donintennessee
Aug 19, 2015 02:22 PM
Cantbuytime
Aug 16, 2015 09:13 PM
Jul 29, 2015 01:24 AM
