Warrior Rear Brake Adjustment
Old May 1, 2008 | 09:18 PM
Dew2008's Avatar
Default Warrior Rear Brake Adjustment
I have to push the rear brake lever WAY down before the brake engadges. I already bled it out but how do I get the brake higher up on the lever? Thanks
Old May 1, 2008 | 11:43 PM
Raptor450's Avatar
You have some more issues, you don't adjust the lever. Either there is more air in the line, you are low in fluid, or you have a bad master cylinder.
Old May 1, 2008 | 11:52 PM
Dew2008's Avatar
Well I read the manual and according to the manual I can adjust the lever. I have no air in the lines and the master cylinder is fine.
Old May 2, 2008 | 12:43 PM
pmcc37's Avatar
as far as i know there is no way to adjust the rear brake lever, there is a screw on the front brake lever. you may still have air in your lines or bad lines
Old May 2, 2008 | 10:16 PM
Raptor450's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Dew2008
Well I read the manual and according to the manual I can adjust the lever. I have no air in the lines and the master cylinder is fine.</end quote></div>
Even if you do adjust the lever, you can't adjust it enough to keep it from going "WAY" down. All my levers have always been real touchy, as soon as you mash it the brake engages.
Reactant
Mar 30, 2022 02:08 AM
greg74
Sep 10, 2019 03:03 PM
Sandman2.0
Jul 21, 2015 09:03 AM
Reactant
Jul 16, 2015 10:29 PM
timster911
Jul 13, 2015 01:57 PM
