Sputter at High RPM
Old Jan 21, 2001 | 02:19 PM
snakeyes93's Avatar
hi,
i finally got my bayou 300 all put back together with correct timing, thanks for all the help. i let the atv idle for about 20 mins just after retiming it. then i rode it around but it sputtered and hestiated every time i gave it a fair amount of gas. ( not alot just to change gears and climbing little hills) i don't see how it could be a timing problem because all you really do is set the valve timing ( not like moving a distbutor side to side to retard or advance) i was thinking it could be the carb maybe running to lean. i looked and couldn't find a carb screw for the rich/lean mixture..... could someone tell me where it is? well any thoughts or suggestions would be great, thanks so much
Old Jan 21, 2001 | 04:39 PM
Diogenes's Avatar
Recommendation: Get a service manual.
The Troubleshooting Guide, Pages 15-2,3, identifies your problem specifically and directs you to its solution.
Diogenes
Old Jan 21, 2001 | 07:52 PM
bayou220atv's Avatar
The fuel/air screw should be on the bottom of the carburetor.
ReconBayou
Oct 31, 2022 05:37 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
