Help with front hubs
Old Jan 21, 2001 | 05:56 PM
Rhunzi's Avatar
I was checking my front wheel hubs like it says in the owners manuel. and opened it up and some kind of liquid poored out. did I just mess my quad up or is this liquid not supposed to be in there. please help me with this
Old Jan 21, 2001 | 06:43 PM
JBSPORTSMAN500's Avatar
Rhunzi,
Did you take the cap off the front hub? If you did then the fluid that you saw pour out was the fluid that is supose to be in there. It can be replaced with Type F transmission fluid, or Mobil One Synt. oil. Just unscrew the small allen head screw on the hub it self and refill it untill it is full and you should not have any problems with the hubs as long as you have not riden it with out fluid in it. Hope this helps. If that is not what you did explain what you did do and we might be able to help.
Old Jan 21, 2001 | 09:16 PM
Farmr123's Avatar
And remember, fill the hub with fluid, then rotate the wheel so the fill hole is down to the 10 O'clock position (slightly down from straight to the side) and let the excess drain out. Do not fill it all the way & leave it that full. There needs to be air inside the hub to allow room for the fluid to expand or you will blow out your seals.
Old Jan 21, 2001 | 10:42 PM
seacow's Avatar
Farm, check the hands on your clock, and look at your post.
Mike, the book shows 8:00 or 4:00 O-Clock to drain excess. (Farm, there's always a critic in the bunch ehh?)
Old Jan 22, 2001 | 09:33 AM
Farmr123's Avatar
Yes, listen to Seacow. I meant 8 O'clock. Go with when I said to drain it to where it pointed slightly DOWN from straight to one side. Many apologies for my mix-up. Too many digital clocks anymore. (hey, I gotta blame something besides old age hehe.)
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
