2 stroke atv vs dirtbike
hey can anybody give me any tips on racing my blaster aginst a dirtbike and winning i have raced a suzuki km 125 i was winning until i reached 6th gear and the km was just hitting 4th
hey thanks for the reply when i raced my buddy we were on the street,the dirtbike seems to have a higher gearing and also higher rev limit like i said after i hit 6th gear my buddys suzuki 125 was just hitting 4th gear now i have done some head work on his bike also
ok for 1 if you have a 12 tooth sprocket with a 42 your definitely taking away from your top end. for 2 if you had a 52 tooth rear then your really really taking it away. your stock gear ratio is 13:40 my suggestion is if you want more top end go with a 14:40 set up which will take away from your bottom end. and if you still want more top end with even less bottom end then go with a 14:39. don't forget a bigger front sprocket is more top end the exact opposite in the rear. hope this helps ya out man.
exmotocrosser
Sep 13, 2019 06:12 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
