2 stroke atv vs dirtbike
Old May 10, 2008 | 02:23 PM
MIKESFASTATVS's Avatar
Default 2 stroke atv vs dirtbike
hey can anybody give me any tips on racing my blaster aginst a dirtbike and winning i have raced a suzuki km 125 i was winning until i reached 6th gear and the km was just hitting 4th
Old May 10, 2008 | 04:30 PM
COTU's Avatar
Race in the snow, mud, etc.
The only thing you can do is use situations where having 4 wheels is an advantage, else forget about it unless the other guy can't ride.
Old May 10, 2008 | 07:28 PM
hey thanks for the reply when i raced my buddy we were on the street,the dirtbike seems to have a higher gearing and also higher rev limit like i said after i hit 6th gear my buddys suzuki 125 was just hitting 4th gear now i have done some head work on his bike also
Old May 10, 2008 | 07:32 PM
bigned1904's Avatar
the only place your going to get him is where traction is a issue
Old May 10, 2008 | 10:55 PM
hey do ya have a good idea for gearing on mt blaster i still think i need more top end i have 12 tooth front sprocket and a 42 or 52 rear,have had yor atv jetted
Old May 10, 2008 | 11:41 PM
mdebuck's Avatar
ok for 1 if you have a 12 tooth sprocket with a 42 your definitely taking away from your top end. for 2 if you had a 52 tooth rear then your really really taking it away. your stock gear ratio is 13:40 my suggestion is if you want more top end go with a 14:40 set up which will take away from your bottom end. and if you still want more top end with even less bottom end then go with a 14:39. don't forget a bigger front sprocket is more top end the exact opposite in the rear. hope this helps ya out man.
Old May 11, 2008 | 12:16 AM
nightmare0098's Avatar
why did you got lower than the stock 13 tooth front sprocket?
Joe454
Nov 20, 2020 01:19 PM
exmotocrosser
Sep 13, 2019 06:12 AM
EIF
Apr 20, 2017 07:15 PM
exmotocrosser
Sep 26, 2015 08:18 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
