jetting a yamaha blaster help
Old May 10, 2008 | 11:31 PM
MIKESFASTATVS's Avatar
Default jetting a yamaha blaster help
i need some ideas on jetting my carb.my engine is 200c ive had the head bored 80 over,carbon fiber reeds,fmf fatty header,gearing front sprocket has 12 tooth and rear has 42 or 52.
Old May 10, 2008 | 11:33 PM
mdebuck's Avatar
pick up an FMF jetting kit, and everything you need should be there including ideas on what to use
Old May 10, 2008 | 11:38 PM
nightmare0098's Avatar
niice. i have a 200cc blaster too. what do i do to re jet mine? i have the stock pipe
Old May 11, 2008 | 12:04 AM
mdebuck's Avatar
well if you haven't changed the pipe then there should be no need to rejet inless you did motor work or your altitude is different from the alititude of the stock settings on the blaster.altitude puts a varuiable on pressure which can change gasoline which will make your bike run lean or rich, same with different temperature
Old May 11, 2008 | 12:09 AM
im fron up state ny so no altitude prob. i just bought the blaster and i was gonna get a new pipe. i just wanna replace alot of things get it in perfect condition lol
Old May 11, 2008 | 12:22 AM
mdebuck's Avatar
right on, well this is what i've done, k&n air filter, fmf jets fmf fatty moto header with fmf power core 2 silencer, and thats about it except for the tires, a new bumper and grab bar. it gave it a hop up and i plan on getting a vito's big bore kit and reeds, and i should be flying
Old May 11, 2008 | 12:30 AM
niice hows the FMF powercore?
Old May 11, 2008 | 12:35 AM
mdebuck's Avatar
sounds good, and gives a notciebale difference for 300 bucks with the FMF fatty moto header pipe
STLyamwar
Jul 25, 2020 04:44 AM
scott1988
Aug 18, 2015 08:44 AM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
315blaster
Aug 8, 2015 08:13 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
