top dead center on foreman 450
Line up the "T" for TDC .. The easiest way is to remove the top cover , remove the spark plug , (using the pull starter) you turn the engine over while watching the intake valve when the intake valve opens (moves down) then closes (moves up) then you use a good light (I use a mini-mag) and watch for the "T" (you will first see the "F" which is the ignition timing mark).. The "T" doesn't have to be dead on the index marks ..
