top dead center on foreman 450
Old May 12, 2008 | 08:18 PM
deerslayer1985's Avatar
Default top dead center on foreman 450
I know You take the cap off to see the flywheel, but which mark is top dead center? I'm trying to adjust my valves. Thanks
Old May 13, 2008 | 06:37 AM
HondaMechanic's Avatar
Line up the "T" for TDC .. The easiest way is to remove the top cover , remove the spark plug , (using the pull starter) you turn the engine over while watching the intake valve when the intake valve opens (moves down) then closes (moves up) then you use a good light (I use a mini-mag) and watch for the "T" (you will first see the "F" which is the ignition timing mark).. The "T" doesn't have to be dead on the index marks ..
Old May 14, 2008 | 08:00 AM
action450s's Avatar
Yup, what he said, I just did mine last night on my 450.
Old May 14, 2008 | 12:14 PM
alright, Thanks alot guys!
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
mark23
Oct 1, 2015 09:57 AM
highwayman
Sep 19, 2015 12:59 PM
patrick.oc123
Sep 15, 2015 02:45 PM
