Front drive shaft
Old May 17, 2008 | 05:37 PM
bakford's Avatar
Default Front drive shaft
Hello all!
I have a 99' Srambler 400. I was greasing the front drive shafts and noticed a small amount of play between the yoke and the output shaft of the gear box ( left side ). Any body know if a "little" play is ok? It seems fine when riding. I was planning on some trail ridding next weekend and repairing it when I got back and had time. I don't know how long it has been like this. Thanks, Al
Old May 17, 2008 | 05:54 PM
MECHANIKE's Avatar
IT DEPENDS ON HOW LITTLE,ARE YOU TALKING ABOUT PLAY IN THE U-JOINT,CAUSE AT THE OUTPUT IS THAT.....
Old May 17, 2008 | 06:56 PM
bakford's Avatar
The U-joint itself is tight. The "yoke" on the output shaft at the gear box has a little play. Thanks for the reply, AL
Old May 17, 2008 | 08:50 PM
MECHANIKE's Avatar
YEAH,GUESS WHAT, MINE ARE LOOSE ALSO, THEY ARE PINNED IN+ THESE PINS ARE HARDENED STEEL,THEY ARE NOT GOING ANYWERE,I'VE BEEN OVER 70MPH AND NO VIBES,IT MIGHT BE DELIBERATE,SO IT HAVES ALITTLE GIVE,ANYWAY I'M NOT AT ALL WORRIED ABOUT IT.......
Old May 17, 2008 | 10:53 PM
bakford's Avatar
Thanks, for the reply. That puts me at ease, but the right side tight. That is why I posted the question. I'll look into when I get some time.
Old May 17, 2008 | 11:04 PM
MECHANIKE's Avatar
yea, its tight against the pin,with the pin it hinges.....
Old May 18, 2008 | 10:23 AM
contentsunderpressur's Avatar
The yolk is supposed to have that little bit of play in it.
Old May 18, 2008 | 02:42 PM
bakford's Avatar
Thanks for the info, AL
KimSJoh
14
Jul 18, 2015 07:20 PM
JackTheKing
Jul 14, 2015 09:09 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
