help bypass shifter switch
The easiest way is to open the hood (where the radiator cap is located) and on the wire panel - find the gray/white wire (power to AWD coils), unplug it and plug it into the terminals for the red/white wires (power when ignition switch is on)........
Each wire set on this panel has a terminal strip, and each "set" should have unused terminals.
This will also give you AWD in any gear without pushing the override button - the override button will still function for Reverse speed control...............
Steeldon
Sep 9, 2015 09:38 AM
