help bypass shifter switch
Old May 17, 2008 | 08:07 PM
dogspower1's Avatar
Default help bypass shifter switch
I have a 95 xplorer 400 and guess the shifter is wearing out have to push it hard forward to get awd to work and only works sometime i would like to bypass the switch
thanks
Old May 18, 2008 | 09:34 AM
Ujoint's Avatar
The easiest way is to open the hood (where the radiator cap is located) and on the wire panel - find the gray/white wire (power to AWD coils), unplug it and plug it into the terminals for the red/white wires (power when ignition switch is on)........
Each wire set on this panel has a terminal strip, and each "set" should have unused terminals.
This will also give you AWD in any gear without pushing the override button - the override button will still function for Reverse speed control...............
Old May 18, 2008 | 09:42 AM
Ujoint's Avatar
I forgot to mention that this "bypass" still works the AWD system thru the AWD switch - so you still have control of 2X4 and 4X4.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Steeldon
Sep 9, 2015 09:38 AM
Jason An Stacy Jones
Utility ATVs
Sep 6, 2015 02:25 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
