rear drive shaft
Old May 17, 2008 | 10:04 PM
trailblazermudrunner's Avatar
Default rear drive shaft
hey can ne one tell me if the hole rear end has to come off to replace the connector boot on a 03 p 360 4x4??? i was looking on ronnie.com and form the looks of it i might be able to dissconnect the nucckel and slipe in a new boot and than re connect the dive shaft can ne one tell me if this is how to do it and also it had a liquie oil on the boot i take it that this is the rear wet brake oil?
Old May 18, 2008 | 07:14 AM
contentsunderpressur's Avatar
It may be possible to do it that way but it's easier to just drop the rear end out of it. The oil you see in there could be coming from the seal where the shaft come out of the motor or it could be rear end fluid coming from your chunk. There is not supposed to be any fluid in there.
Old May 18, 2008 | 11:37 AM
why would there be fluid in there isnt there bearings in there? how hard is it to drop the rear end? what is there in there that i could possible F**k up and cost more money?
Old May 18, 2008 | 12:38 PM
There is a seal where the shaft comes out of the motor and rear end. That seal should keep all the oil in the motor or rear end. Where the swaybar pivots on the frame there are caps. Pop the caps off and there are big allen bolts in there you have to take out. Once you disconnect the shocks, rear end breather hose, break lines and take those bolts out the rear end will fall out. The U joint on the driveshaft will just slide off the shaft that comes out of the motor.
Old May 18, 2008 | 03:26 PM
okie thank u this dont sound to hard now u say the drive shaft will just slide off there is to shafts ???
Old May 19, 2008 | 07:50 AM
Yes, once you drop the rear end the drive shaft will just slide off the shaft. Then it'll just pull out of the rear end. There is a spring on the rear end side that has to go back in though.
Old May 19, 2008 | 05:01 PM
all i have to do is seprate the rear end enought so i can replace te boot and than right back togeather so is the drive shaft going to slide out of the rear end side or the motor side
Old May 19, 2008 | 06:12 PM
That's right. You may not have to take anything loose except the two allen bolts. You may be able to pull it back far enough.
Old May 19, 2008 | 06:14 PM
The drive shaft will slide off the motor side. It also slides off the rear end side as well. There is a spring on the rear end side that holds to tension on the shaft so it don't slide off the motor side while riding. If you pull the shaft all the way out make sure you slide the spring back on before you put it in the rear end.
Old May 19, 2008 | 06:28 PM
thank u so much for the info i think ill tackel it this weekend when in not in skool now if this spring is in there to hold tension on the drive shave wont it be hard to slide every thing back togeather?
